Pam411 Problem: Can't set time
CycleBuyer
275
32
Hi,
I can't set the time on my new 411.
Is there anything I can do short of sending it back to the TD?
The watch winds and runs, but I can't get the crown to move the hands -- all the crown can do is wind.
Thanks!
kilowattore
13,970
6,428
What happens when you pull the crown? Do you hear a click when it changes to time setting position?
CycleBuyer
275
32
I hear a click but instead of the hands moving all I can do is wind.
kilowattore
13,970
6,428
Try removing the crown guard and see if the crown needs to be pulled out further
CycleBuyer
275
32
The crown guard was the only thing holding the crown in. Looks like I have a keyless problem. The TD said try locally to fix it or send it to China again.
Anybody have any US-based repair persons? I'm in SoCal. Thanks.
kilowattore
13,970
6,428
It might be very easy to fix. You need a rubber ball or a duct tape ball to open the case back. You will see a little screw close to where the stem inserts into the movement. Insert back the stem gently and screw in that screw tightly. It should work after.
There is a list of tutorials with pics in my signature, you will find some helpful info for sure.
CycleBuyer
275
32
Wow! OK, you just saved me a bunch of time and trouble! That was EXACTLY THE PROBLEM.
Thanks very much, I appreciate it!
CycleBuyer
275
32
Oh yes! Newbie owner 1 : loose stem 0.
Another victory for the lads.
My gratitude!
