PAM382 help
Tudor1101
31/10/17
Croatia
Hello!
I want to buy Panerai 382
I need advice with buying new one superclone with Custom designed Asian automatic movement to match the genuine Panerai P.9000 or older version with Asian 7750 automatic movement
I heard that parts for repair/movement service are essentially non existent for newer version
Any suggestion would be helpful
Thank you
mysterio
9,793
867
The A7750 version would probably be easier to repair as the parts for the movement are readily available. But the newest version looks and functions like the gen movement. Up to you which route you want to go, although the older version might not be as readily available. Good luck! :)
