thanks for your help!
other than the bigger chance for scratches, are there any significant differences of the plexi? is it also anti reflective coated? (or is it not even necessary there?)
I am tempted to pull the trigger on the 372sc - only reason i was hesitating so far (besides the plexi concerns) is that i was hoping some of the flaws would get corrected soon - does not seem that way thought as they have not changed much with the sc2 version.
Hi johnsx
I'm not trying to be rude, as always
But you are a bit lost and you need talking to you clearly
PAM 372 is WITH Plexy crystal because it is following this feature of an historic model. If you like a PAM 372 you have to get it with a Plexi or it will not be a 372.
It would be the same as getting a PAM 127 and removing the Crown guard because you don't like this device or changing the crystal to a flat crystal because you don't like the domed.
On the other hand, why are you worried about new versions more accurate and most likely more expensive if you are willing to accept a completely different crystal?
That doesn't make sense my friend
That said, replicas of PAM 372 rep are reps in evolution at this moment
There is no perfect version, Noob is the best one from the front and in the wrist, Clone2 is the best from the back, but there is not a decisive version
ALE
