PAM364 noob - Hand size..... Any help???
nous
78
Hi all,
I'm trying to change movement to my Noob PAM364 from an Asian to a Swiss one
and I'm wandering what size are the Noob hands?
120/200/25/20? Maybe the guru ALE or any other PAM expert can help....:adoration:
I know that watches equipped with the old 21k Asian7750 had no issues with ETA swapping.
Any help appreciated?
mysterio
9,794
866
The PAM364 is fitted with the newer 28.8K A7750 so it needs modification to be able to use hands that will fit an ETA movement. I don't have measurements of the hands on the PAM364 (although I do own this rep) so that's about as much help I can give at this point.
nous
78
Thank you Misterio,
After CNY I'll try to send an email to Noob Fac and see if they can help.
I bet that this modification will not be a problem for Domi though.
For the moment I'll focus on how tol fit the A6497-2 engraved bridges
to my ETA/Unitas 6497-1 movement and after I find proper to change gears from low to high beat.
Fingers crossed ;)
mysterio
9,794
866
Thank you Misterio,
Fingers crossed ;)
You'll send an email to where? You must be well connected. :)
nous
78
I'm importing LED lights from Asia and noob is the only well known factory. All other makers except KW are a mysterio..... ;)
Sent from abroad using TapaTalk
D
d4m.test
Guest
I have fit gen hands on an A7750 rep Panerai movement and rep hands on a gen Panerai 7750. You will need to move the cannon pinion cap over from the rep movement, but that's not impossible.
nous
78
Thanks Grimlocktime.....
We learn.... Trying I think
