In the current ratings, it is considered as a First Class rep due to this:
But in the dealer's website (referring to a non-TD here):
So if the rotor is removed, this will be correct as per gen specs. Will this improve its classification as a super rep?
On June 2012 H maker released a replica fitted with automatic A7750, impossible accuracy since the gen has Manual OP XXVI movement, but the general construction and finish is a First Class replica. Always bearing in mind the matter about an automatic movement instead a manual one. Due to this reason we cannot consider this PAM 308 a Super rep.
Note: The Genuine Movement is also a 7750 with the Rotor Being Removed... Users of the Rep can also simply remove the Rep Rotor and it will function as a Manual Handwind watch like the Genuine
