Pam299 SS Bracelet Question
estebanelequente
378
Hey everyone long time no see! I am in the market for a Pam299 or similar 44mm pam super or first class rep with a bracelet as opposed to a leather band. My question is will the bracelet out of the box fit an 8 inch wrist. I have run into the issue with a few reps where I have to sit on a watch for month or two until I figure out how to source extra links and I don't wanna run into that problem again. Also are the pam rep bracelets worth a damn? Thanks for the help and if anyone is selling I'm buying fell free to PM me. Thanks!
m07h80
234
I have 299. I had to remove 3 links from the bracelet. I'm currently using a Asso strap at the moment. What I'll do, when I get home, I'll measure my wrist for you. I should know it really.
m07h80
234
So I have a 6.5 inch wrist. As I said in my previous post I had to remove 3 links, which is probably about an inch. The bracelet is lose on me as well. Might be a little tight on a 8 inch wrist.
The Dude
959
I've got a 7.25" wrist, think I had to take out 2 links if I remember correctly. So, as above, may be tight on 8".
Actually, I'm not sure how many links I took out, so disregard this post.
Berlok
17/1/15
Anyone with experience know if this will fit a 6" Asian wrist?
How's the quality of the bracelet?
D
d4m.test
Guest
The bracelet is very high quality. The gen has more precisely beveled edges, but that's about the only real difference. I have a 7.5 inch wrist and I removed 2 links. I still have them in case you buy the watch and the bracelet is too small.
Dochere2
404
SC
The quality of the bracelet o the 299/7 models is actually quite the conundrum, given the fact that the bracelet is of very good in fit and finish, yet the watch typically sells for a similar $ amount as its cheap as all hell leather/rubber counterparts.
Yes, you can set-up a stainless pam bracelet to fit a 6" wrist. You can also fit it to a 8"+ wrist, though it may take a second bracelet to achieve (not positive on the stock size, largest I have sized one for was 7.5").
m07h80
234
One of the main reasons why I bought the 299 was the good quality SS bracelet, nice and easy swap out for a leather strap if I want a change. Toro still has them for a good price as well.
winz
189
The latest bracelet from noob 299 and 297 very good quality, only the screw on the bracelet very bad, but overall super quality.
But can i use my bracelet to pam 164 or pam 356 by noob?
If i want use this to bettarini luminor case like pam 111 and pam 308 where i can buy the end links?
emdeevee
2,337
1,727
Southern California
This is one of the best PAM reps out there, it's really fine, and the bracelet quality as said above is very good. I have closely compared it to the gen and like the bloke above says, the edges of the gen bracelet have the slightest beveled edges while the rep is just straight. I used very fine grain sand paper and cape cod polish to bevel the edges of mine. I love the watch, it is indistinguishable from the gen. I also got mine from Toro who has the deal of the year on them so hurry up and get it before he sells out of them!
winz
189
If combine pam164o or pam356o with this bracelet i think it will be awesome
Like gens this one :
http://www.beverlyhillswatch.com/pa...steel-black-dial-bracelet-pam-164-2wbsyd.html
But anyone can confirm if i can use my pam297o noob to pam164o noob?
Thank you very much
mysterio
9,794
866
I doubt you would be able to buy end links only. You would have to buy the whole bracelet.
As for fitting the bracelet on a PAM356O...
Need I say more? ;)
winz
189
Need I say more? ;)
Wow, very nice on pam 356
How reliable a7753? Compare with a7750?
Are bracelet from 297o noob can use for all bettarini luminor automatic case by noob factory?
Nofd1977
21
Need I say more? ;)
Man that is one sick Pam! Where did you get the SS again?
mysterio
9,794
866
The A7753 is on par with the A7750. Not all bettarini cases. They have to have the notch for the end links at the sides of the case.
I got it from an old PAM328L which I sold as a PAM312. :D
winz
189
thanks for the info, very useful to me, heheheh.
can i use that bracelet to pam 243 noob or pam 312 kw?
mysterio
9,794
866
PAM243 - No, because the head does not have the notches required. You can after some sanding down of the endlinks using a dremel.
PAM312KW - No, because the thickness of the KW case is thicker than the 312L from where the bracelet came from.
winz
189
luminor bettarini and luminor 1950 use same endlink?
i only have a bracelet pam 297o by noob fact
