PAM292 V6 | Ceramic Case Chip
nick168fng
Hi all,
I had recently discovered a small chip on my PAM292 case. I tried scrubbing it off with no luck and the color appears to be light greyish. Is the V6 case supposed to be full ceramic or merely ceramic coated?
Thanks.
nick168fng
The chip did expose a lighter color tone. Is it possible that the case is just a ceramic coated?
mysterio
9,793
867
A picture would help to possibly determine the composition of the case underneath. Sometimes descriptions won't cut it (or in this case chip it). :)
nick168fng
Yes, please refer to the image below.
mysterio
9,793
867
Looks like a thin chip. It's ceramic. It's properties are similar to rock so it would chip/crack and not dent/bend like stainless steel. The appearance is not the same underneath the surface that has been worked on.
nick168fng
Thanks for the prompt reply. Ouch, this would be a permanent scar? Has anyone tried using sharpie? :wacko:
GIMMESUMREPLICAS
82
21
If you can find one in the same or at least very close color tone, then I don't see why you woulndn't try it. From what it appears, the chip seems to be off-white color and it is quite visible.
nick168fng
It's actually closer to a light silver alloy color. I guess there's only one way to find out.
