I want to use 217 case to build a homage.
So I need to know some internal case/dial dimensions to make sure that the different movement can be fitted in.
Thanks, I'll do it.In that case might I suggest asking the folks over at HomageForum. They might be able to help you along with that homage project.
Thanks, I'll do it.
But I think great RWI members here like @marlin2284 , @Strodda or other modders can give the answers also
Joe,The 217 case is made to house the 6497 movement. The 6497 has a diameter measurement of 36.6mm, so you need to put a movement in there that has the same diameter measurement, or you will need to make a movement ring. The dial is roughly 41mm.
