Pam177M with engraved Officine Panerai with blue ink?
Belgium
35
Is there a PAM177M Noob? With Scratch-proof sapphire crystal with colorless AR coating, SuperLumed dial and hands (SuperLuminova C1+C3), Platinum plated and super bright steel composite movement bridge, refined cutting angle and details, engraved OFFICINE PANERAI with blue paint, 6497-2 high beat 21600vph movement and caseback that are individually fully engraved each time.
I love the PAM111M Noob, but I prefer the titanium case (the darker brushed look is awesome).
Thanks for your advice.
Dr.Verylong
10,405
12
The current 177s are actually quite nice. However I always thought the majority of the platinum plated movements had printed OP on it. At least mine have.
ALE7575
Section Mod
19,846
422
There is not Noob 177 at this moment
The H maker version is pretty good.
Concerning Ti : OK it is darker and beautiful but it is much more sensible to scratching and therefore it is very delicate.
ALE
allez
343
133
in German speaking area of EU
Hi!
Does anyone know the "best version" of them?
Or let me write ist so: are there important differences/ improvements between the both (newer) Versions M and N??
I did compare the 177 from trustytime and puretime... I´m not sure :/
thx!
Spboudart
4,398
To get a 177 as you want it you need to buy a Noob factory 111 and and H factory 177.
Switch the dial/hands/movement from one to another.
It takes less than 5min to do it.
Then you can sell the 111 for 170$ and it'll sale within minutes. Final cost of your 177 will be 50$ above regular price but you'll have the movement you want and the better dial.
Here's mine, pictured with my gen next to it:
Some did even better, the lume on the H backplate is better, so you can switch backplate, but that's much more technical and will take you longer. I'm lasy so I didn't do it.
ariffza
188
Sead has the high beat 177 with the engraved movement. That is the best 177 OTB at the moment.
