Pam111 Problem Screw
Tahor
181
Hi Guys,
I have a problem and need your help.
Received a Pam111 Noob V4 a few weeks ago from Sead and now wore it 2x.
Before I stowed it in the box, I found that the screw from the safety hoop of the manual wind had probably come off and been lost, so that the Wohle Part is loose now.
Where can I get such a screw and and fix it and how can it be that you solve yourself by wearing 2x?
Thank you
mysterio
9,793
867
You open the caseback in a clear area. Then turn it over (make sure to not wind the watch, the screw inside a running movement would be disastrous). The screw should fall out. I don't recommend re-attaching the screw unless you can fix it without it getting unscrewed again.
Tahor
181
No, i did not open the caseback. The screw was in when i received the watch but i missed to tighten it
mysterio
9,793
867
I see. Normally you don't need to tighten the screw after receiving the watch but I see quite a few threads being posted regarding this screw turning up missing.
capice
2,713
558
screw from the CG....depending on the case, I could have some...where do you live? If in EU I will ship it for free
