PAM111 N V4 Noob with Y-Incabloc fix & Longer Micrometer Screw
reezfan
26/11/15
Hi.
The new PAM111 N V4 Noob has been released!
From what I can see on the photos it fixes the infamous incabloc to the Y-incabloc and the micrometer screw is longer. At the same V3 price.
However the swan neck is not updated.
I am not sure about other improvements.
This comes at right time as I have done months researching on the PAM superep and ready to pick the V3 with incabloc mod.
Will get the V4 soon!
Size:44mm x 15mm
Movement:Platinum plated Asian UNITAS-6497-2 21600vph hand-winding movement with dagger swan neck regulator and flat-top movement bridge blue screws, all blue letters are engraved then filled with blue ink rather than painted on the movement directly, with E-Serie
Functions:Hours, minutes and sub-seconds display
Case:1:1 replicated 316F high grade stainless steel case, new style crown guard with ball-bearing.
Crystal:Scratch-proof sapphire crystal with colorless anti-reflection coating (Swiss standard, single-sided, same as genuine)
Dial:Superlumed dial and hands (lumed with genuine Super-LumiNova C1+C3)
Bezel:Polished stainless steel bezel
Strap:Brown calf leather strap
Clasp:316F high grade stainless steel tang buckle with detailed engravings (same as gen)
Water resistance:>50 Meters
Remark:1:1 replicated from a genuine watch sample, all parts are interchangeable with genuine
attached is the photos.
h5tuu
64
I may as well make my first post on this thread as I've just pulled the triggr on a V3 yesterday.
This newer V4 to my fairly untrained eyes appears to have the V3 fat crown and lever? The Y incabloc does however look better, I'm wondering if I should ask my TD to source this instead of the V3 he's currently sourcing.
ALE7575
Section Mod
19,845
419
Sorry to be a little spoilsport
This release is already commented in another thread from below post:
https://forum.replica-watch.info/vb...n-a-PAM-111?p=2576616&viewfull=1#post-2576616
I copy-paste my opinion:
IMO this is a comercial trick to finísh stocks of V3 parts, the crown is “fat” V3, the CG lever is of course the inaccurate noob lever as usually, and the caseset don’t seem a V4 with nice lug contours and detached from the cushion shape as real V4 has.
Regarding the Y-incabloc it is not GEN Incablock, is a nicely modded rep Incablock, the same as currently used in new rep PAM 127 movemnts. Of course lyre spring is also rep. Swan neck spring is the same inaccurate Noob as always. Micrometric screw seems a bit improved with longer head and longer thread (but not enough) and the tip is wrongly pointed (maybe the same screw used in new 2015 reps of PAM 127).
The OFFICINE PANERAI engraving on bridges is like a joke. Reason enough to reject this watch
I think is not correct to call it PAM 111 V4, becuase the caseset is not (or at least no completely) a V4.
For me this rep is just a Pam 111 V3 with a nicely modded Y-incablock and horrible OFFICINE PANERAI engraving on bridges.
Calling this version PAM 111 V4 is MISLEADING and for me a commercial trick as above commented
Another problem to create more confusion
Be careful
ALE
ALE7575
Section Mod
19,845
419
It should be V3.2 not V4..
Engraving on the caseback is awful.
This is the point and I agree with you
But seeing the engraving on bridges it would be a V2.9…. LOL
ALE
ebzen02
3,015
2,081
Intime pic of the bridge engravings are much nicer
Tengzai
Intime pic of the bridge engraving is much nicer
+1
Having a dilemma getting a v4 from Ryan or V3 from elsewhere.
It does seem to have a fat crown and non v4 case? I cant really tell.
ALE7575
Section Mod
19,845
419
+1
Yes, these concrete engravings look better although still thicker than gen and usual V3 engravings
Unfotunately there are a lot of variations between all sources of these so-called Noob "V4". See below a link to a post where is compared a QC pic of this "V4" from TSwatches and a V3. It is in the middle of Intime and Puretime pics:
https://forum.replica-watch.info/vb...ots-QC-pics?p=2584192&viewfull=1#post-2584192
The case on Intime Catalogue is obviously V3 with bad lug contours
Therefore we have a watch wrongly called "V4" without concrete specifications, mixing V3 and V4 parts, with longer but pointy screw, with variable engravings and rep modified Y-Incabloc
To keep away IMO, if you are looking for the best version available
In relation to get a V3, it depends (as previously) on your luck, if you are lucky you could get a V3 with some V4 improvements: crystal, slim crown, and nice lug contours (correct CG lever will be almost impossible)
ALE
Bozz
2,748
PT and Intime incablocs are different. Look the shape! The Intime incabloc seems a modded rep and the PT incabloc seems a swiss...
ALE7575
Section Mod
19,845
419
Puretime Incabloc is also modded without doubts, but nicely modded (notches on the upper edges are missing)
I saw the Intime Incabloc seems worse but maybe another batch from the manufacturer making the modd
ALE
Bozz
2,748
ALE
Intime is a V4.0 and PT a V4.1 :p
blacke
31
Hey members! Just want to share my QC pics for V4 from TS. I'll post more when I received the watch.
https://forum.replica-watch.info/vb...ics/page115?p=2586077&viewfull=1#post-2586077
Thanks guys for the info... my topic:
https://forum.replica-watch.info/vb/showthread.php/280347-Pulling-the-trigger-on-a-PAM-111/page3
Bottom-line: Noob is clearing up their warehouse so let others buy the transition versions and come back within a couple of weeks... just keep an eye on the QC pictures meanwhile. The real V4 will come after all V3 parts are gone! It's not even summer so just have some patience !!
Fiestyleo
119
Has anyone purchased an intime.co PAM111 V4? Do you guys recommend this as my first pam purchase?
SerafinWatch
231
23
Switzerland
I received mine last week. First PAM and dont regret it.
I dont care about inacbloc shape or other details, because I dont concentrate it on it yet. Recommended.
Fiestyleo
119
Nice! What strap did you go with? I'm debating the rubber one but not sure of the quality.
SerafinWatch
231
23
Switzerland
prepare to buy a oem panerai or di stefano strap. might cost as much as the whole watch... go for the rep rubber in the meantime. chinese leather feels like plastic. for perfect look i recommend a matte and not too colorful strap. brown croc looks awful on that.
