I'm quite interested in a nato strap but not sure how they actually work.
Do they just use the normal spring bar on the watch itself and is threaded through them instead of over them?
And could you use a nato strap with a PAM111?
You would need a 24mm NATO, otherwise it'd look a bit awkward... Very easy to install on the watch, and it would use the original screw bars. Here's a couple of photos for you to see what the ones I make would look like on the watch.
