PAM029 GMT hand is running slow
slay
DO NOT TRADE WITH ME
28/3/09
559
220
I just got a new 029 noob from Ryan and I noticed that the GMT hand is running slow and therefore loses time of the GMT time zone. It's not just a little bit, I'd say at least 4-5hours per day. I reset the hand several times now but it keeps going out of sync. Watch has the modded ETA 2836 GMT movement.
Has anyone else had this problem before?!
PreA
140
Ive got the same problem with my rolex explorer II. I think the gmt wheel slips sometimes. Its not actually running slow i think.
My 'solution': set time to example 12pm. Then set your gmt to prefered time. Then manually rotate time trough dates untill youre at correct date.
This works in my case. Somehow if i set the watch up in this particular order i dont have any problem. I think it has something to do with the date/gmt wheels slipping.
maybe this works for you aswell.
slay
28/3/09
559
220
I'll give it a try, thanks!
PreA
140
Allright. Please let me know if it works cause i want to know if its just my watch or with all gmt 2836
slay
28/3/09
559
220
If the GMT wheel slips, maybe adding a dial washer on top could help?
Will report back later, so far it seems to be working.
slay
28/3/09
559
220
Unfortunately that didn't help, it started to run slow again :(
Raddave
Administrator
67,017
18,637
Your GMT hand is not draggin on the dial any where?
Maybe your hand is loose ?
slay
28/3/09
559
220
Nah, there's about 1mm of clearance between the GMT hand and the dial.
slay
28/3/09
559
220
Anyone else before I send it back to Ryan?
