Its quite easy to fix. Use some model enable paint. Will last longer than the factory paint.
+1 on enamel paint.
It's very easy and you don't have to be precise.
Apply a layer, then rub the excess paint with acetone.
Some of the paint will be removed.from the numeral, but don't worry and repeat until you're satisfied.
Choose a matte paint.
Good luck
This is my milgauss CB after restoration:
+1 on enamel paint.
Good luck
have double ar coating at crystal or not?
Progress update! Just done the first coat. Can't believe how easy it is. Fill it in, wipe the excess paint with finger and the paint remains where it should! Thanks for advise
