PAM026K H fac V2 High Beat movt problem
vinnie007
90
Hi guys,
I have a PAM026K H fac V2 with High Beat movt and i am having a problem.
Watch is great but there is something with the movt and i don't know how to solve this...
If the head is up and the back down it runs smooth, but once flipped it runs for 20-30s and it stops...
If i flip it back it will start running after 30secs.... Does anyone know how to solve this?
Thanks
justlounging
2,725
100
Hi,
It could be possible that the dial is slightly loose and therefore by flipping it upside down, it shifts slightly and stops the seconds hand..if that is stop, the movement stops as well..
and when you flip it right side up, the dial again shifts down and all is well and fine again..
if i am correct on this diagnosis, after you disassemble the watch and remove the hands..the dial should come off very easily because either one of both dial feet have broken off..use some rodico or double sided tape to secure the dial onto the movement again..
vinnie007
90
Hi,
Thanks for your answer... Have been looking for 1/2 hours yesterday, disassebled it but when i assembled it it stil had the problem... So i checked the movement again and some of the screws in the movt were very thight, so i loosened them and now it is working again! Thanks
ALE7575
Section Mod
19,846
422
Lucky man !!
ALE
