- 23/6/17
- 1,390
- 3,544
- 113
There are a few white-dial PAMs out there now. What made you narrow down to the 1499?
The 1499 has three variants:
ZF
KW/ V6F v1
KW/ V6F v2
Go for the KW/ V6F v2 which has the updated case with better lug shape and thinner case as per Gen. Other variants have incorrect case thickness (18.5mm)
There's also the 1523 which has a 42mm case with the same dial design.
Other white dial PAMs you can go for are:
1. 113 - Hfac has very recently updated it.
2. 561/ 563 - KW/V6F special promotion models. First class rep bordering lower status. Toro has them for $129. Also 44mm Luminor case.
The PAM499 was introduced just ten days ago by VSF.
VSF, a spin-off of KW/ V6F makes high quality PAMs. It's an excellent choice.
In all honesty if you are only trying out the look of a white-dial Panerai, it looks very similar to the PAM563 I have just shared an image of; suddenly makes a lot of sense for $129 vs S308 for a 499.
But if you want the highest quality rep, then go for the VSF 499 followed by V6F v2 1499 (blue seconds hand, vintage color lume, much thinner case) as I am sure rep factories have vastly improved their quality in the 2-3 years since the release of the 561/563.
seems like the 1499 v2 is out of production, the 561 is very interesting but i cant find any review on rwi(again)...
Afaik there should be a recent 561 release from ZF with correct case thickness. All KW versions like my 563, although nice, had wrong case.
The case thickness on these handwound ones was off by hair, ~0.3mm.
i see, just a hair of difference..
another dealer said he can source me a kw785 at around 200usd, should i pull the trigger? i think its suits my liking but im not sure whether its a good rep
I can't seem to find a PAM561 from ZF on the TDs I've tried, but there is a PAM563 which ZF released last year:
https://puretime03.com/pam563-p-zf-...e-dial-on-black-rubber-strap-p5000-clone.html
It all comes down to what you are willing to accept. The ones that have been mentioned before are good reps, they are not super reps but they are good reps. The PAM602 (or what some TDs call the white PAM785) from KW is also a good rep. It has a better dial compared to the DSN version, but the hands are not correct (KW uses a modern hand set, DSN uses the correct Pre-V hand set). Here's the review I did on the DSN PAM785 set.
https://forum.replica-watch.info/th...e-davidsen-pam-785-luminor-8-days-set.208959/
Different thickness, different bezel, different lugs. There was a comparison post by ALE when the gen 8 days line was released but I can't seem to find it now.
