Pam swan neck issue!
bgood11
648
116
1e0a3d02104db79d7c8fae822dcf8bfa.plist
Hi guys and gals. See the attached image. I just received this watch and the hands aren’t turning. I think this is the issue. Easy to fix? Any advice? Thanks
Raddave
Administrator
67,017
18,656
Oh dang , it looks like you are missing a screw , and id bet it was lodged in the movement somewhere
bgood11
648
116
Thanks Raddave shouldn’t the Regulator Lever be inside the swan neck too?
jb3md
826
345
Yup it should be.
Where are you located? I sent a 127 to user oascom for similar issue he fixed it quickly and seemingly easily.
Sent from my iPhone using RWI
bgood11
648
116
Also I bought it M2M and just checked the pic from the OP.
Looks like it was like this before he sent it to me which implies he knew it was dead/not functioning. What can I do? Can I get any moderator advice from you? ;-)
bgood11
648
116
Yup it should be.
I’m in UK. Any recommendations appreciated. Not an easy fix I can do myself?
Raddave
Administrator
67,017
18,656
Yes it should , but it probably moved due to the missing screw
Raddave
Administrator
67,017
18,656
I doubt very seriously you can fix it yourself , as you might need to remove bridges ........
bgood11
648
116
Thanks man. As I say pissed off as he said it had been serviced and clearly knew it wasn’t working when he sent it to me.
Raddave
Administrator
67,017
18,656
Contact the seller , see how he wants to handle this , if no resolution , fill out a helpdesk ticket ....
i would also highly suggest you hack the watch now to prevent further damage
bgood11
648
116
Ok will do. Thanks. How can I hack it?
Raddave
Administrator
67,017
18,656
Put it in the time set position (by pulling the crown out )
Hazing
And So It Begins... Again
9/5/19
5,188
4,463
The swan neck and Micrometer screw are completely decorative, right? So that shouldn’t be the issue - should it?
If that’s the case, it’s most likely just be the screw that’s bouncing around in the case that’s causing the watch to stop running. Which could have jammed in there at any time during shipping. So it’s possible that the loose screw just jammed in there while in transit. Just saying it’s possible because I’d like to think someone wouldn’t have outright lied in a sales thread.
I also cant believe the forum didn’t catch the issue in the original sales thread. Usually people are all over things like that which is what’s great about the m2m area. I hope it all works out in the end but as jb3md pointed out, oascom has fixed issues similar to this before and that watch is definitely in need of a service. Hopefully he (or anyone) can fix the swan neck.
PAM_BOY
10,949
31,663
The swan neck has no measurable effect anyway (only for optic), but you have to find the small screw or make sure that it´s not in the movement!
Merry christmas
bgood11
648
116
Thanks for all the help guys much appreciated. Have a great Christmas
