PAM Slipping/Sliding on Manual Wind
lpl
649
147
New Zealand
I know it could be a double post from the past, but as of September 2017, what are your recommendations in tackling this problem? The movement is A6497. I know for a fact that it's not overwinding the movement as the slipping happens earlier on, during the beginning of the wind. What's the recommended fix for this and if it is worth spending the money replacing or fixing it.
Also, in terms of the 6497 movement, which movement do you guys recommend me to use to replace this? What's a good brand and where can I get it for cheap?
Thanks.
Zulu44gmt
441
44
On mine I thought the movement was shot too... got worse and worse Each week... turned out the smaller winding gear had only become loose. It's a reverse threaded screw. I would check that first.
Sent from my iPhone using RWI
lpl
649
147
New Zealand
Do you mind posting pictures as to which one it is?
Zulu44gmt
441
44
Loving it! RWI App
Seefeld
Proud supporter
393
194
Sorry guys I know it's an old post, I'd like to know the end of the story, I have the same issue, slipping wheel when winding, I guess I just have to work on one wheel, probably the little one, but I'm not so sure and dont' want to damage everything :)
superspark69
3,148
2,210
Sheffield, UK
I would say if there's issues, send it for a service and then you know you've got a nice serviced watch for peace of mind
Seefeld
Proud supporter
393
194
Thank you, yes that'd be the best choice, but I'm trying to save a 250 euros service for a 250 euro watch! Any other suggestions?
Seefeld
Proud supporter
393
194
Your watchmaker has much better prices than mine (250 euro and 450 for a chrono!)! I would do it for 80 pounds
capice
2,713
558
service on a A6497/98 normally is between 85 and 100 euro, parts excluded with a full service
Seefeld
Proud supporter
393
194
Ok guys so let's say I'm not able to find a service at a good price in my area, because I'd do it paying 100 euros! The point is, seen the above video, is it a work that can be done by a non professional like me? Probably it's just a screw on the little wheel (i could just do that). My impression, but I'm less than a beginner, is that the problem is in the little wheel.
The watch works and I can wind it, I just see that the wheels slip back a little.
kilowattore
13,967
6,418
Crown slipping might mean the winding gears need to be tightened (easy solution) or a problem with the main spring (not easy). It's a watchmaker's work. Check the trusted dealers section, there is at least one watchmaker based in EU.
