pam reps and water resistance
Oliver71
22
Just wandering if any of you good people tested their reps for water resistance. I see noob watches are rated to 50 mtrs. Do I take that with a grain of salt or is this accurate?
Cheers.
D
d4m.test
Guest
They're about 60-40 (good - bad) when I test them. They usually leak from the crystal or crown and are generally not too difficult to waterproof.
That is unless you want to waterproof a chrono.
COLDI
9,712
118
Yup. Grease the seals and add proper O-rings.
Then my test is gutting the watch. Sticking in a dead movement and blank dial and then I go swimming. Correct seals as needed :)
anonymus
124
had my 156 tested to 5ATM (best the machine could do) also with 3atm under-pressure..
although i did by this from a member f the forums who had waterproofed it..
but worked out great anyways ;) (i was a bit worried when the crown is not screw-in since who knows what o-rings are in there, but no problems what so ever, my new poolwatch ;)
ALE7575
Section Mod
19,846
422
Cheers.
Reps need get a waterproofing professional service to assure a reliable waterproof.
If the rep watch has not get seviced you will never have the guarantee.
ALE
