Pam 90 Project.. need some help
beano2004
162
Well i went and bought the power reserve movement and already in route is the Pam90 complete watch that will be used for parts.. now here is the question i need help with what current rep case will work with this movement i currently need approx 7.5mm in thickness for this movement to work...
Any help is appreciated as I dont want to start collecting watch cases, and i know there are alot of Pam experts here.
Thanks in Advance.
bean
here is a pic of the gen pam90
now a pic of the rep pam90
vaccum
1,884
14
If there is a difference between the automatic and manual 44mm case I want to know :?
I have seen a lot of Pam auto (063, 104, etc) and all cases are the same the only difference is the metal ring that holds the movement in place, the movement of course 2836 or 7750. I could be wrong :wink:
vaccum
beano2004
162
Vaccum if that is the case then a JImmy case will work with this correct?
vaccum
1,884
14
I guess so....remember nothing is a given on the rep world. You need to get the parts and try, the you can tell for shure :wink:
beano2004
162
well then i know what i have to do.. what do you think about the hands?
vaccum
1,884
14
Hand size info....
Gen ETA 7750
Hour 2.00mm
Minute 1.20mm
Center Seconds 0.25mm N/A
Subdials 0.17mm
New Asian 7750 28.8K BPH
Hour 2.00mm
Minute 1.20mm
Center Seconds 0.20mm N/A
Subdial 0.20mm
The subseconds hands are not the same size.....
ganjamun
247
Someone seriously need to replicate that Datewheel to be installed on ALL PAMS.
beano2004
162
Reg, i believe i will need that spacer after all.... lol
This sure is going to be some project now all i have to do is gather all the pieces....
bean
razerreg
271
you got it bro [smilie=icon_thumleft.gif] ill send it your way this week.
beano2004
162
Reg, anytime you need something you let me know... your generosity is greatly appreciated....
bean
