PAM 607 Help
Dondada
168
33
I like the PAM 607, this is what is listed on the Super Rep list...
PAM 607 - KW-V6Fac P-series Ceramic decorated A7750 NON-inverted KP9000-V2) The most interesting version for A7750 lovers. // KW-V6Fac P-series Ceramic decorated KP9000-Seagull V2 NON-inverted The most interesting version for Seagull lovers
How do I decode this and where do I find this?
Are these all modification done or is it a Specific PAM 607 that comes with all of this..
Please, any help would be greatly appreciated towards my first PAM Super Rep.
Thank you!
mysterio
9,793
867
That is one of the problem of lists. It does not provide enough context. What you have there are actually two watches, both made by KW factory. The only difference being the movement, the A7750 is cheaper to repair as parts can be replaced but is more expensive, the Seagull version on the other hand is cheaper but if the movement breaks, repair usually entails replacing the entire movement which is more expensive than parts replacement. Check the PAM bible on what the movement looks like, although being a closed caseback it really does not matter. The important thing is making sure the watch is indeed made of ceramic. Some cheap versions use a DLCed stainless steel/titanium case, which is wrong for this rep (the legit ones have REAL CERAMIC in the description, something to look out for).
Dondada
168
33
Thank you!
Thank you for your reply.
This was very helpful, I appreciate it!
Question... the PAM 508 is very similar to the 607.. do you know what the difference is between these two?
Also is there anyone out there that does further work on the Panerais to better them or make them even more accurate?
