PAM 441 Seagull arrived. Big problem.
ct83
87
Hi my PAM 441 with the Seagull movement arrived.
Rotor is totally loose. What steps are neccessary to fix this?
It is from Toro.
Pic inside
Gesendet von iPad mit Tapatalk
PolonusTM
2,131
711
it is glued, so snap and glue back in.
emanuel366
11/3/15
I just received my PAM 441 last night - and had the same issue!
Did you end up taking it to a watch-maker to fix?
mydnytrydr
7,800
222
That should snap right onto the hub without issue ....... even a :baby:could do it !! Good Luck!
Crazivi3tdude
252
22
got me a pam441, luckily everything is perfect here. I wonder if time will tear it :unsure:
Crazivi3tdude
252
22
btw, when i manual wind, the crown never stops. is this normal? how are you guys 441 acting? i have the seagull movement.
craustin1
15
Yes, perfectly normal for an automatic. A mechanical non-auto does stop around 32 full turns, depending on model.
idinwo01
1,393
46
These movements have rotors that are press fitted on to the movement. In order to reattach, simply align the rotor and press it down.
If your rotor is already loose, it may be best to take this as a sign that the pressure fit needs to be reinforced. To do this, place a tab or two of GS Hypocement and let the rotor dry over night. After that, seal that baby up and your rotor issues will be solved.
rockstardc
92
I have the 438 but with 7750 movement. Lume seems to be very good. Is it different from the Seagull because I'm thinking of getting the seagull movement because I messed up my old watch
