HEy guys,
I have a question, I am a bit confused. I noticed on TD websites (chris/miffy) 2 versions of 417 NY KW($258) and V6f($218). I always thought KW=V6F, the only thing that comes to me is maybe one is older model case/dial, but it seems like the more expensive one has incorrect movement.KW for 258 has swan neck and incorrect standard 6497 bridges, where the cheaper one has no swan neck and Cortes de Geneve decor which I think is correct for this boutique model movement same as Hmaker on Klockis/ALE review.
Can someone please clarify, I just want the most accurate case/dial/movement 417, price is very atractive now. Not clear why 2 versions are listed. Angus has one labeled V6F and only one version which seems to have correct movement, should this be KW?
Thank you.
Thank you.
