PAM 390 Overwound/other? Help!
elratboyo
A while back my 390 from Sead started making an awful clicking noise when I wound it. Sounded like the mechanism was slipping and was not holding any more than an hour reserve. any help appreciated - in pic, the screwdriver pointing to the offending part, and also a video of me winding to show what's happening. Easy fix or beyond economic repair?
Thanks in advance
https://www.dropbox.com/s/uwec4ltj4o6tcxc/MOV_0595.mp4?dl=0
Bozz
2,748
Perhaps those three screws are loose. Try to tighten with care.
shoes
393
Sounds like the keyless works are broken. Where are you based?
az erik
79
Looks to me like the click spring popped out from under the click, part you are pointing at, very simple fix. Just feel if any of those wheels are wobbly first
Strodda
Supporter 'smith
4,440
42
TX/USA
From what I can tell, I agree. It looks like the click is not locking in the ratchet wheel's teeth and its just snapping back whenever you try to wind.
Whatever it is, any fix would be easy and parts are cheap.
az erik
79
Yup, a whole movement is only $40ish
