PAM 388 Seagull Rotor Deco Loose
Luke Warm
247
Had a similar problem. It's faux and only glued on, as is the rotor.
Strodda
Supporter 'smith
4,440
42
TX/USA
I would recommend just pressing it in. It should be tight enough to hold. In case the watch ever needs to be serviced, gluing those pieces in will make it very difficult to remove them without damaging.
Luke Warm
247
If that doesn't work then maybe apply a microdot of Loctite.
Visceral
54
It appears pressing back in worked for the time being.
azelaya
109
where do you buy it?
Went to go change a strap this morning and heard something loose. The rotor itself does not appear to have any issues so I am assuming that this piece is decoration. Can it be snapped back in or will I need to glue it? I had a set of case openers in my amazon wishlist that I had been waiting to purchase so I guess I get to buy myself a gift. :devil-1:
where do you buy it? im trying to buy this same version with the correct engraving .
thanks for the information
PAM1983
1,174
Honestly the smallest amount of elmers glue when you press it in. it will pop loose when you go to service it no problem. any stronger glues and you wont get it off again
