PAM 382 Bezel click?
packerjames95
107
13
Hi guys, I just received a pam 382 bronze from toro bravo, and I noticed that the bezel is clicking when I press down on it - I was just wondering if this is normal for this watch (and the submersible line from Panerai) or if it's an issue with the watch?
Thanks!
groot
124
Thanks!
Mine had the same problem. I strung a piece of dental floss between the bezel and the case. Problem solved. There is a post somewhere showing how to do it but I just can't seem to locate it. But it is easy. Just use a pen knife to cut off any excess length and tuck the floss in.
mysterio
9,793
867
I've searched and that particular tutorial is nowhere to be found. So I made this instead.
https://forum.replica-watch.info/th...ng-bezel-dental-floss-and-silver-foil.404451/
I'm expecting @kilowattore to include it in the list of tutorials later. :)
groot
124
D
d4m.test
Guest
Thanks guys! I ended up trying the dental floss method and it worked like a charm!
