- 18/3/06
- 1,647
- 1
- 0
I pulled the trigger on a 195 from Davidsen - also liked it enough to order 2, The PVD work is very good - enzo has commented elsewhere that Davidsen has a proper, bonded/blasted, PVD, not simply painted on.
I ordered mine w/ the Swiss 6497 - I wanted surety of parts for this one down the road ...
The good:
* the case is of good quality / veracity
* the dial
* the PVD
* 'fat' crown
* CG is solid; pin looks good also
* the 3 ATM test appears to be no idle boast - I have got all my "Davidreperai" submerged.
The bad / not ugly actually, maybe indifferent ..:
* CG lever is not flush - have mentioned this to David and hopefully this is to be corrected in future ones
* the bottom lug screw does not go into the case fully .. a singular flaw? NO, for this was the case (no pun) for both that I ordered
* you may wish to add to the lume's robustness
* if you consider the gen's PVD, it has a subtle sheen to its PVD coating; the earlier [some current!] reps were AWFUL, with an almost enamel sheen to them .., and David's PVD is more matte ... a PVD w/ a modicum of sheen would be perfect
* 1 x 195 arrived w/ a poorly adjusted stem - so it's problematic to set the time, but getting easier with use (I'm not one to rip open the caseback to do this - enzo would have no issues!)
2 pics to keep "modem burning" to a min ... likely I'll post more later (have to study for a professional exam; this is my glorious procrastination!)
Bottom line: Davidsen's 195 is a rep worth owning. Some more tweaking will make it even better.
Strap is a Golden-Sandy:
--- BBB
The good:
* the dial
* the PVD
* 'fat' crown
--- BBB
