Pam 187 date problem ?
stockwatch
293
12
Just got the 187 beautiful watch but anybody had problem with date getting stuck ? From other post I saw that date pusher can be brake easily so I shouldn't use the key to change it.
Should I service the watch of just let it be ?
Thanks
Sent from using Tapatalk
fanerai
INMATE
1/10/15
105
I have used the date change tool multiple times. It's just a matter of being careful. Don't try to go too fast and don't be forceful. If you abide by those simple rules, then using the date change at 10oclock isn't a problem. Good luck.
mysterio
9,794
867
So is the date actually getting stuck or are you just asking if anyone has encountered the date getting stuck?
stockwatch
293
12
I mean to say is that date does change right away at 12 but instead it goes slowly changing from once it hits 10 o'clock and fully chance by 12
Other replicas it changes it right away at 12. So is that normal with 7743 movement ?
fanerai
INMATE
1/10/15
105
That's exactly how it happens with asian 7753 movements. The show starts about 10:30 and is over at mid-night. Completely normal....from my experience anyway.
ALE7575
Section Mod
19,846
423
I agree, completely normal
ALE
