PAM 183h arrival & first wind
DIAMOND-DAI
556
24
My PAM 183H from Puretime is due to arrive today and given that it would appear that I overwound the 026k I bought off the forum last week (doh!) I just wondered what the protocol is for first wind?
20 turns? 30 turns? Don't want to break this one when it arrives today!!!
DD
cwazy1
3,812
How did you overwind it? You'll feel significant tension in the crown once its fully wound.
DIAMOND-DAI
556
24
Perhaps I didn't then as the crown built up no tension when I was winding it, hence why I thought I'd wound it too much!!!
robbie888
157
normally you will feel more resistence in winding just before you reach the end. I allways stop winding then and not go to the point the crown stops.
Alex_P1
2,030
14
You CANNOT overwind a watch.
You can if you like your spring in one piece! PAMs can be overwound, unlike Rolex, as they do not have a mechanism to protect the spring once they become fully wound.
co-axial
23,225
I agree witm mm, you can only overwind with brute force
ALE7575
Section Mod
19,846
422
I disagree, you can't overwind a watch.
I think midasmook is meaning:
- You can wind completely a watch
- If the watch have mechanism of protection you can follow turning the crown and nothing happens.
- If the wacth have no mechanism of protection and you try more winding you will just broke the Spring. And all finished.
The overwinding doesn't exist !!
Isn't it??
ALE
midasmook
1,489
When you wind a watch all you are doing is tightening a spring. When the spring is as tight as it will go you can't wind it any more, laws of physics, therefore no you cannot "overwind". On a manual watch the winder will just stop when it's fully wound, if you try and force it further you could break something so don't!. Auto's have a clutch system so when the spring is fully wound the winding mechanism slips.
The term "overwound" is often misused to describe a non running watch where the winder will not turn in the winding direction, this normally (but not always) means the spring is fully wound but there is something preventing the springs energy being transferred to the drive train.
co-axial
23,225
Thanks MM, so i was using a wrong term...as i meant it is possible to break somethimg if you force it...
(btw i just gave it a search, seems as the term is used wrong often, lol
http://forum.replica-watch.info/vb/showthread.php/unitas-6497-winding-70250?t=70250 )
KBH
7,168
With enough force, you can break anything, even a manual wind movement. But you'd have to almost do it on purpose.
MM is right though, you can't accidentally over wind a movement.
Alex_P1
2,030
14
Ok, I agree with this, sorry for my hasty earlier comment!
However, I'd like to point out to anyone that thinks winding a PAM is the same as a Rolex, that some care is required not to damage a component part of the watch when the spring is fully wound.
Use finger tips and you'll be fine, better to be safe than sorry
TastyTreats
3,460
Never Never Land
makes perfect sense.
I have never had an issue with over-winding and all my watches are automatic.
