PAM 1349 California 45mm hand finished PVD
Belkin12
Supporting Vendor
26/10/12
340
1,252
Ukraine
Gentlemen,
this is a 45mm build inspired by the 1349 with olive textured gradient dial, carbon steel heat blued California hands and patinated pvd case. Please note that its not a 1:1 rep but a homage. Actually this is a homage to "an absolute homage to the original Radiomir and it’s enduring legacy".
PM for details please.
Briefly about the build:
- High quality 45mm Radiomir rep case. Significantly improved water-resistance. It was previously dismantled, ceramic blasted and hand treated PVD coating to create a "controlled" aged look.
- 4mm thick high dome pot-shape crystal.
- Spring-loaded screw-in crown. Engraved. New improved O-rings for better water resistance.
- Modded and correctly engraved display CB.
- Vector traced and custom made aluminum 1349 Cali dial. Olive or "deep green" hue. Grainy texture + gradient. Cream lume and golden RR.
- Custom made 0.3mm brass backplate. 00 1349 stamped. Soldered dial feet for 6497 movement.
- Custom made carbon steel California hands which are shorter to fit a 36mm dial properly. Hands are mirror polished and heat blued. Cream lume.
- H3 CP/HW. CP flattened and mirror polished.
- Completely serviced (washed, oiled, re-assembled, regulated) a6497 movement. The wheels and ratchet screws are re-polished and heat blued.
- Movement holders made to firmly secure the movement inside the case.
- Titanium lug tubes.
- Custom 26x24mm vintage brown slightly distressed leather strap with off-white stitch. Size is 125mm x 80mm.
- 24mm screw-in (removable) buckle. Hand treated PVD coating.
Please note that this is not a regular factory watch but a custom handmade build with certain deviations from gen and its own peculiarities. Though all the parts and services were done professionally it may still have certain imperfections or specific features.
And a few pics:
Pavelic
9/4/25
Gentlemen,
And a few pics:
It's an amazing job you did. Is there anyone for sale?
