PAM 127 - Rachet and Crown Wheel ?? (Franken)
Leewei
471
Hi Guys,
I have a PAM 127 Noob Edition.
Looking to franken it slightly.
Apart from doing the Incabloc mod and the painting the wordings to GOLD.
One big tell tale sign would be the Rachet and Crown Wheel which most modder neglected.
I have found the supplier Ofrei who supply the Rachet and Crown Gear but the shipping cost alone cost US$39 to world wide (You guys think worth it ?)
I did the math and calculated the teeths. Rachet gears has 56, Crown has 35 . Both ETAs and Asian one matches. Are they directly plug and play ?
Thanks.
Below would be the noob 127 movement...check out the 2 huge silver gears.
Big one : Rachet gear...small one : Crown gear.
The gen movement (There is no slope on both the Rachet and Crown Gear) :
MMs
1,924
yes, direct swap.
worth it?
if you're doing the repaint and incabloc, yes, otherwise, no.
make sure to get that long swan neck regulator pin too.
ALE7575
Section Mod
19,846
423
yes, direct swap.
worth it?
I agree with MMs
And bear in mind too the shape of the support of the Swan Neck spring. Where they are the two screws to fix the spring to the balance cook. In the Noob movement is completely different !!
ALE
