PAM 1176 Luminor GMT needs help pins/ screws !
TomTab
Hello,
I need help regarding replacement screws for the PAM1176 VSF, for some reason I can't explain why I had the watch "loose" up my sleeve a few days ago when I took off my leather jacket. Luckily it didn't fall down but there is no trace of the little screw!
I bought these PAM special screws: https://watchparts24.de/ Spezial-Sch...Bandfixation-an-Panerai-Uhren-2-Stck-24-mm
but the thread at the end is wider/thicker and cannot be screwed in!
Anyone experience or idea?
Thanks
effinski
80
73
Hello,
Thanks
I bought a mixed screw set for glasses, watches, etc on Amazon for 7-8 €. There should be some for your need.
https://www.amazon.de/YIXISI-Mikros...177656&sprefix=brillenschrauben,aps,95&sr=8-7
Reactions: TomTab
TomTab
@effinski Many Thanks, but my problem are the pins that hold the strap!! it is a 44mm modell. The srews are enough long and apparently the same but the thread doesnt fit!!
PeterRei
400
29
There are spring bars looking like screws. For example on panatime. Or you can ask a dealer for screw.
