Hey guys,
I have a recently acquired pam111 modded with the docheres' usual treatment and craftsmanship. I just have a question about the crown, as well as the power reserve.
Is the crown supposed to lock in position entirely or remain in the position in which you can manually wind the watch? Meaning, once the CG lever is released, should you be able to wind it from the position the crown is in, or is it supposed to be pushed into place, and pulled out lightly to wind, and fully (to change time). I'm experiencing the first example where once I release the lever I'm able to wind it, than I can pull it out once too change time. Sometimes I'll hear two clicks, but even so with the crown "pushed in" all the way, I'm still able to wind the watch. Also, I find the watch not making it through the entire day on a wind when wearing on and off, is this typical, may it have to do with what I'm experiencing here above?
I'd like to also add that it's difficult to push the crown in after the setting the time I have to do it almost forcefully while closing the lever, in which even with the CG and lever closed you can still turn the crown hearing the clicking of the manual winding.
Thanks!
Thanks!
