PAM 092 DOA, questions
iliketowatch
786
Hey guys,
I picked up an 092 Arktos from a M2M deal, watch was rarely used by previous owner. Seemed to be packaged relatively well, but watch is dead on arrival, can't get the movement to start. Any suggestions or tricks I might try before taking it to a wachsmith? I am going to put it on my winder for 24 hours, the winder has a setting for the 7750 movement. Anything else you might recommend? I do believe the seller who says the watch was working when shipped so I'm hopeful this is a simple fix.
Thanks!
rolexwatchfan
4,225
802
Standard issue with 7750. Wind it manually an then give it a little kickstart-holding in one hand bump it gently against the other palm. It should start right up.
