PAM 087 Replacement Crystal?
Marv1nn
225
Hey guys,
Not sure what happened to my crystal, but for some reason the date magnifier has some sort of an x shaped scratch on it. Not sure if it’s in the crystal or the magnifier.
Anyone know who/how to source a replacement?
Thanks!
mysterio
9,793
867
rnrprof - have you tried him?
Not sure how prof can help, unless it's a damaged AR film issue. If it's a scratch on the sapphire, it would be difficult to near impossible to replace as the factory that made it is already closed.
Martycus
4,574
3,804
[FONT=verdana, geneva, sans-serif]Do you know the diameter for it? Try timebymail.com, crystalbrandnew.com, ebay or etsy for a replacement[/FONT]
JOP
703
179
Any thought about what it is?
If no one open the case, can't be a scratch that needs 5Kg force to be created.
I hope that they are plastic debris from movement spacer or any other dirt could be.
Even if it is a real scratch, i will bet on a professional optician for its' recovery.
Str1xt
506
254
That looks like debris inside the watch . I can see one peice in front of the other where they over lap. Might just be the way I'm looking at it though.
mysterio
9,793
867
Well no one can say what it is, especially from a single picture. Maybe have a watchmaker open it up and see. The way the cyclops is made on the underside of PAM crystals, which I believe entails boring into the crystal itself and not as a separate magnifying crystal glued onto the inside, would require expertise (not familiar with opticians, I only know of them as the ones who dispense the lenses prescribed by optometrists).
Grimlocktime
DO NOT TRADE WITH ME
3/5/13
3,031
257
Hey guys,
Thanks!
Are you sure that’s a scratch and not an reflection? Have a look under a loupe.
Reactions: Islander36
