Couldn't find clear answers on this, I really missed my old 048, picked up another recently, when I received it the rotor had detached.
I've had another PAM where this happened. I know usually the bearing is just pressed it. This won't "press" back on and stay. I could do glue, I've glued one before, but it didn't stay for long. I'd much rather just replace it with a generic rotor if it will work.
Anyone know if its as simple as unscrewing that center screw, removing the rep bearing then reuse the screw with a generic 7750 rotor? In the picture of the generic rotor from ebay, the bearing is in the rotor already correct?
