I imagine thats it mate, hands touching when face down. very strange.
You have a few options.
1, live with the slightly loose hands. could be a problem if the watch gets knocked as the hands could come off and scratch the dial.
2, get a modder to sort the issue out. wont cost much but the wait might be a pain in the neck
3, be brave and get the right tools and try fixing it yourself. fairly easy if you have the right tools, a steady hand and patience.
Tools you will need for a diy job are. watchmakers screwdrivers, sticky ball or roll of duct tape, hand remover there are two types-plunger and presto i think, hand setter tool, tweezers preferably plastic, something to protect the dial from scratches and something to protect the hands (i use a piece of plastic from a little baggy over the top of the hands), a dust blower.
Remove cg, remove cb, set watch to 12 midday, unscrew movement holder screws put them somewhere safe, press stem release button with screwdriver to release crown and stem DO NOT PRESS TOO HARD or you might mess the keyless up, put a piece of paper or card on the back of watch then turn upside down carefully to remove mvt and dial.
place plastic over the hands remove hands with hand remover then use either tweezers to hold the hands when reinstalling (i use a small piece of masking tape on the tip of the hand it's much easier than tweezers) press hands on flat and straight with hand presser, blow any dust off dial then re-install mvt and dial blow any dust from the back, replace crown and stem carefully while depressing stem release button and moving/turning the crown back and forwards lightly until its in, replace mvt holder tabs and screws, replace cb replace cg. Job done!
Or just send to a modder if it seems a little too much lol.
