Not quite correct guys...
While the gen 029 GMT came in predominantly T-dial flavour (only few gen L-dial 029 were ever seen in the wild) the replica 029 is a copy of the L-dial 029, and a spot on one at that. I believe BigL was inquiring about the right lume color match for his rep 029 which is L-dial, and should be off white / cream, deffo not aged tritium color.
The gen 029 T-dial is different in look and apperance from 029 L-dial, T-dial 029 one comes with markers and indices "pushed in" towards the centre of the dial, while L-dial 029 somes with more spread out numerals and indices towards the rehaut. There wes never a correct rep made of a gen Pam029 T-dial, the one LoS picture shows in his post above.
Many forumers have opted for changind the L Swiss L into T Swiss T txt under number 6, mainly due to lack of knowledge about L-dial and T-dial 029 dial differences, and while Ziggy has done number of these mods (letter L into letter T), the resulting dial isn't actualy "correct" if you're about splitting hairs. You end up with L-dial arrangement with T Swiss T dial under 6 o'clock.
Since a rep 029 is a good copy of 029 L-dial, it should be left as is, IMO, just re-lumed a bit better to SLuminova C3, that's all that needs to be done dial wise. Some newer models will require a hand stack upgrade, but early models like EL and Honpo are spot on with hands.
cheers,
babola
