Order ChazingTime Explorer II Clean
theclaw25
180
23
One of my Favorite Trusted sellers.
Order from ChazingTime Explorer II 226570, Clean DD3285.
Pay: 11/22/2024
Status: Processing
QC: Coming soon
asusundevils1971
21,861
34,322
In Your Head
Clean does make beautiful Rolex watches but your lift angle should have been set at 55 degrees for the 32XX movements.
Reactions: theclaw25
theclaw25
180
23
Thanks for the head up! I just read about the time graph in certain angle in this particular movement, but I couldn't find it.
Reactions: asusundevils1971
asusundevils1971
21,861
34,322
In Your Head
Here is one of many times the lift angle has been talked about on here. Thought it was best to use dogwood's post as he is our Rolex movement guru.
The lift angle is set incorrectly on the time grapher for the DD3238. The lift angle should be set to 55 degrees for both the DD3285 and the VS3235 on which it is based. The lift angle is used to calculate the amplitude. Setting the lift angle too low (in this case 52 degrees rather than 55 degrees) will result in a calculated amplitude which is lower than the true amplitude. Ask your TD to provide you with a time grapher picture with the lift angle set to 55.
Edit: apparently it could also be 53 degrees. There’s some disagreement online about this.
Scroll down to Rolex and it shows the lift angle on the 32XX movement.
theclaw25
180
23
Hi just curious, did Chazing send you a video of the timegraph measurements?
Nop. Actually I asking if they can measure again a 55 Degree. The answers was: "for DD movement the correct actual is 58 . but alot buyers in forums say must be 52 . so now we all set at 52 unless buyers say 58".
theclaw25
180
23
I'm approved but after one of the adm. sent me a note about the right measurement from certain movement I asking again with a copy about it and she answers me this: we later will send u timergraph when the qc guy wake up. So I just waiting.
theclaw25
180
23
Video with timing graph provided at 58 degrees because it is a DD3285 super clone, not a Gen. Gen that has to run at 55 degrees. Executes excellent. Admin can delete photos that are out of context.
Reactions: Explorrertime
febocamoal
19/2/24
Which website are they currently using? Not sure where I can check for updated seller information
