Omega speedmaster
dottfe
14
Hello,
I would like to buy an Omega speedmaster watch replica.
what do you recommend? Model and manufacturer.
I would like a watch very similar to gen.
Thanks
eBoy
14,125
23,409
Hello,
Thanks
You picked the only popular watch of which there is no good replica available.
The reason is that there is no movement available that the replica factories can use to get the sub dial spacing right. Sadly, with the available movements the Moon Speedy reps that are available, the spaces between the sub dials are so large that the rep is easily identifiable as one from across the room.
APjumbo
watchaholic
2,551
3,759
Canada
Speedmaster is a good gen choice, rep for everything else.
dottfe
14
Hai scelto l'unico orologio popolare di cui non è disponibile una buona replica.
Il motivo è che non è disponibile alcun movimento che le fabbriche di repliche possano utilizzare per ottenere la giusta spaziatura del quadrante secondario. Purtroppo, con i movimenti disponibili delle ripetizioni Moon Speedy disponibili, gli spazi tra i quadranti secondari sono così grandi che la ripetizione è facilmente identificabile come quella dall'altra parte della stanza.
Thank you very much
CrackShotDave
68
Great info on her.
I was just searching for info on a speedmaster moon watch, i would love a wind up one :( my real one was stolen and uninsured..
APjumbo
watchaholic
2,551
3,759
Canada
In the omega section there should be a whole thread on the speedmasters
To sum it up, either go cheap quartz and it will have correct subdial spacing but the dial will be flat.
Or go mechanical movement and the subdial spacing will be a little off but usually the subdials are recessed nicely. OMF makes these.
Got20Mate
6,739
10,033
Currently wearing my VSF Seamaster Pro black and its absolutely brilliant - A truly excellent rep.
Got20Mate
6,739
10,033
I'm new here and I've been buying my Rep from a Chinese seller for now. Now I am looking at the offers of trusted dealers from this forum.
If you have any more details on who you've bought this from, let me know. Massively intrigued
Hinclimincli
2,606
1,876
I guess it's the OMF Speedmaster, it's currently the best option indeed. Check any of the TDs websites, any should be able to source it.
Reactions: Got20Mate
