Hi,
It probably has very small screw pins in it. You need a good small screwdriver and lots of patience to adjust it.
The pins that are tight will simply chew up if you use a poor quality screwdriver, and be prepared for a pin then
simply won't come out, you may have to swap links from one side to the other.
/mds.
