Hi
There are ways - some good, some bad.
Unfortunately its not as easy as the normal SMP where you just remove the bezel.
I followed someones advice to use a hair dryer to soften the double sided tape under the insert. Then use your fingernail or wooden toothpick to loosen it, trying not to bend the insert.
I managed the hairdryer bit ok, but the adhesive was too strong and I eventually wrecked my insert. So i got a new one from Angus @ Puretime.
I've not heard of any better method other than remove the bezel...
