GT40 said:Hi...
Can anyone advise me, I've been wearing my Ultimate PO for about 4 months, a few days ago I notice the Pearl had dropped off. Can anyone tell me where I could get a replacement and are the easy enough to install.
Any help appreciated.
daytona4me said:If you have the UPO , you can swap the bezel out. I checked into this as I was going to swap bezels from orange to black and then back after a couple months of wear each.
You cant get the pearl seperate, you have to get the bezel and the price that was quoted to me was $40 but maybe it's come down since.
I think Silix's PO's are different than the UPO that the other dealers sell, so I would be careful and do more research before ordering one only to find out it wont work.
02transam said:So, how do you change the insert?
jmd33 said:02transam said:So, how do you change the insert?
I don't have a PO (yet) - but on my SMP and GMT they just pry off. So, you tape the watch (I use painter's tape), then take a knife (I use a case back remover), put it between the watch and bezel (I start at the 5 o'clock), and *pop* - off it comes.
With my Omegas there is a small "plug" (????) with a tiny spring underneath at the 8 o'clock - DON'T LOOSE IT - and a bezel spring that holds it on (don't loose that either) - both can go flying if you're not careful.
