oiling 4130 rotor
CsViking
MULTI ACCOUNT
28/11/21
132
23
hello guys i have a clean factory daytona with sa4130. rotor does sound is it good idea if i put verry little amound of 9010? or let like it is?
RX7GP
1,349
704
Good question. I was also curious about that. 4-5 drops of 9010 to rotor bearings can be healthy. You can also grease the gaskets while you are at it.
Reactions: Giammy
CsViking
MULTI ACCOUNT
28/11/21
132
23
The other thing is if it’s good we need to clean first the rotor of a new watch? Becouse we don’t know what oil clean factory used there so we need to do it from zero? Becouse we may mix oils ? But the basic question is .Is it bad to put 9010 there ?
ffnc1020
37
13
I think HP1300 might be better, I put 3 drops on 3 of the balls and it worked really well.
Reactions: Giammy
CsViking
MULTI ACCOUNT
28/11/21
132
23
i read that HP1300 is thicker oil and the problem is it will cause problems after time to the performance. also the 9010 its too thin that you need really small amount becouse if you put a little more the oil will move under the ballbearings and lead problems to other parts... but i dont know whats the right here.
CsViking
MULTI ACCOUNT
28/11/21
132
23
HP1300 should be fine
thanks for the answear bro can you tell me please becouse im new in that job what are those oils that they mean? (epilame-oil1-oil2-grease0-grease1-grease2) oil1 is 9010 oil2 is hp1300 right? and the others? im on to buy oils and i have 9010 hp1300 and 9412
