Noob 390 case problem
I purchased a 390 which arrived just yesterday and wanted to change the band but the lug screws just turned without removel which is weird so I conacted the seller who said are they just stripped.I had no idea so I pushed them out with a wooden toothpick. The strap bar ends are damaged and flatten . Looking at the hole in the case the case it does not look to be threaded.I think this is a fault from the noob factory?
The case should be threaded right. My 111 is.
Any one had this problem recently?
