- 6/4/20
- 8
- 0
- 0
Hi there,
I bought a Noob V10 3135 without any movement on aliexpress but not sure what did I get. For sure is not a Noob V10 as I compared the one I receive with some V10 in forums. My main issue is that I want to mount a gen 3135 movement but the outside diameter of the 3135 is 28.5mm and I think the inner diameter of the case is 30mm so the movement has a lot of play inside and is floating. Any one knows what rep has a 30mm diameter?. Other supliers and forums say that mounting a gen 3135 is a direct swap and the diameters should match. I couldnt find movement spacer rings or anything so Im not really sure what did I get. Any light in this will be appreciated as I need to open a dispute and send the watch back.
