- 19/10/13
- 7
- 1
- 0
I just dismantled my Noob Daytona V2 or V3, for servicing the 7750 movement. i measured the back groove for O ring gasket and it seems larger than most. I measured ID 33.1mm and OD 35.1mm (see pics) . So the width is 2mm width but most ones I've looked at are between 0.5 _ 0.7mm. which should i buy? also in the groove is some pitting (see pic) will it effect the gasket? its on outside edge not inside.
#2 pushers - where can i find the clip that goes at bottom that holds it into shaft ? one broke while removing
