Noob 2846 Help
SenorCoveyy
87
31
A friend gave me this FREE yesterday as she was packing to move, because she knows I’m into watches. Today I take a closer look and see it’s a 2846 movement. I also noticed the ETA marking, So is my assumption correct or is it a fake? Also how should I protect it until I can use it for a build? Should I leave it in the case as is, or separate the movement? I recently came across a Tudor 94010 Mil-Sub and made that my next piece I get. Though it is a non-date is the use of this movement possible? Sorry for the Dumb questions I appreciate y’all taking time to inform me. I find myself getting more into this hobby and loving it
Rx4Time
Supporter, Panerai lover
12,080
10,965
What are the lug engravings? I'm guessing it's a Tudor day date that someone dropped a refinished day date dial on. It might be worth it to try and restore the original dial and bring it back to what it was if I'm correct.
SenorCoveyy
87
31
I could really care less about the case/dial they are scrap as far as I’m concerned, I care about the movement. From what I’ve gathered the first Tudor Snowflake Submariners models 7016/0 and 7021/0, used ETA 2483 and EFA 2484 movements, respectively. Meanwhile, the second duo, models 9401/0 and 9411/0, used ETA 2776 and ETA 2784 movements.
Rx4Time
12,080
10,965
Check the case. It's it's a genuine Tudor there is still a nominal value for someone wanting to build a franken.
SenorCoveyy
87
31
this case the movement at question is completely unmarked with the Day-Date. I could use this movement in a Tudor Milsub build correct?
