Newest Aquaracer Calibre 5 300m 2016 model
jovame
147
111
These last few months several new versions of the Aquaracer Calibre 5 300m with 43 mm case have been introduced.
There's the version with the Seiko NH35A 24J automatic movement, with the new 2016 Tag logo (see e.g. http://puretime03.com/aquaracer-300...black-textured-dial-on-ss-bracelet-nh35a.html).
Then there's also the 2015 version (with old logo) with an Asia 23J Automatic Movement, a steal at $ 138 (http://www.ttw-138.com/index.php?main_page=product_info&cPath=41_211&products_id=16257).
Also the 41 mm version with a quartz movement has become available (http://www.ttw-138.com/index.php?main_page=product_info&cPath=41_211&products_id=16212).
And now, if that's not enough, PT and Intime introduced this week the "Aquaracer Calibre 5 SS MKF 1:1 Best Edition" with an A2824 movement. According to Intime:
"MK Spent a year to make this to be perfect, 1:1 replicated from a genuine sample.
1. 1:1 Replicated the dial, hands, bracelet and clasp from a genuine sample.
2. Very High-Quality silver plated on bezel number as genuine.
3. 1:1 same thickness as genuine."
And I have to say, at first glance it looks fantastic. But then you realise that MK has made a momentous error:
the "rider tabs" (or whatever they're called) are all in the wrong postion on the bezel. Instead of sitting at 5 min., 15 min., 25 min. etc like on the gen, this rep has them sitting at 0 min., 10 min., 20 min. etc.
Pic of the gen:
Pic of the MKF rep:
Now I ask myself, if you have bought the genuine watch to study it, and spend a year in perfecting a replica, how can you overlook this??
Or is this just a pre-QC prototype that PT and Intime have used to display on their site, because this fault seems easy to correct: just rotate the bezel 5 minutes worth (30 degrees) before inserting the ceramic inlay and fixing it to the case.
Or perhaps I'm overlooking something and this is not a mistake at all?
garnier
637
76
Also the numbers on the bezel are wrong, too much space between them, look at the 30 for example, and they are thiner
jovame
147
111
Personally, i can live with the thinner numbers on the bezel.
What bugs me the most is these incorrectly placed "tabs" on the bezel. Especially when you realise that they got this right with all the other earlier replicas of this watch (perhaps by other factories).
Even this $ 138 rep gets it right:
garnier
637
76
Maybe you can remove the bezel insert and paste it again in correct position
zsolie
145
I have check my dealer, and they said all batch are manufactured with this fault.
I wonder, if the bezel can be removed and glued in the right place?
jovame
147
111
Good of you to confirm this.
So it's not just a prototype where they put the tabs in the wrong place along the bezel, it's the whole production batch!
Frankly I'm amazed at the level of incompetence some of these factories show, especially after going through the trouble (and cost) of buying a gen and "perfecting" the rep for a year.
Even after several years of buying reps, they still can surprise me!
It's a pity though because for the rest this seems a really nice watch and could have been a real seller.
Hopefully the factory realizes that a possible lack of succes of this rep does not necessarily mean there's no market for this Aquaracer, but rather that they have to correct the bezel for a V2 version.
Removing the bezel insert and glueing it back in the correct position might work if you're really handy, but i'm afraid i would end up damaging the bezel...
ZoomBoy
2,533
288
Yeah a real shame here. And I'm sure they'll equate the lack of sales due to no one wanting this model - instead of seeing that the bezel tabs are all in the wrong spot. I was prepared to pull the trigger on this one, but not until that issue is fixed. If not, there's plenty of other watches in this bracket that are just as good looking.
Campbelloni
264
I was also very interested in getting one of these but that's a pretty terrible mistake to be made. Taking into account that this version is over $300, I'd expect it to be right.
I could possibly live with it if they made this "v1" cheaper until they fix the issue.
sm1th3rs
17/2/17
THANK YOU for pointing this out, was in contact with PT and almost pulled the trigger.
m838855
82
Hopefully they fix IT soon. Execpt for the bezel its a nice watch.
WindJonah
129
Don't have any MK reps but certainly on the BP and Noob Omega PO reps the bezel insert is simply stuck in with double-sided tape. So it would be a very easy job just to remove and replace it rotated by 30 degrees.
Probably a good idea to remove bezel itself first. But again this pretty straight forward - you could buy a cheap tool from eBay, use a (protected) knife to pry it off, or rep bezels are sometimes lose enough that you can pry them off with your fingers.
There are several threads on Omega forum about bezel insert replacement (and Tag construction looks to be identical):
https://forum.replica-watch.info/th...sert-removal-45mm.198999/?highlight=hairdryer
or on full bezel removal:
https://forum.replica-watch.info/threads/diy-bezel-removal-tool.193027/
bene1337
294
709
I'd rather go with a TD from our forum. If you have trouble with them the admins here can always help you but they won't if you go with Andrew. But if that's not that important for you, you will be fine with trusty. Very fast replies and Andrew ist a very nice guy.
Sent from the RWI mobile app
Mushoo
12/3/17
Is there a trusted dealer on here you recommend for that particular style watch?
