Need to replace a movement
Blackrose
538
I have a Rep Rolex Explorer Pro Hunter and the movement was loud when I got it. I wore it in the ocean and didn't loctite the back and salt water got in and there was water damage and the movement is corroded with salt. I love this watch but do not ever wear it. Can somebody please recommend a good watch maker who can replace the movement and about how much does this cost. Thank you.
Bonesey
8,926
69
Depends on the movement.
21j = $20-30
Clone 2836 = $80
ETA = $150+
Not including labour. Is the dial and hands ok or are they damaged as well?
intheshadows
456
I wouldnt loctite the caseback!
Grease up the o-ring and tighten (not gorilla strength tight) and the caseback shouldnt be your point of entry unless the o ring is pinched.
Oh also, wrong sub-forum for this post.
Q5?
15,272
I'm sure ThinkBachs would recommend using loctite on your caseback screws......
http://forum.replica-watch.info/vb/showpost.php?p=905305&postcount=11
I don't believe he put a new one in- to be sure, you need to pull the stem out completely and share a photo of it for us to comment on. This is the only way to verify it....
When re-installing the stem, you must use Loctite® Threadlocker Red 271. Watchsmiths are cheap bastards and never use the good stuff! Just a little on the tip should do it. Glad you shared this so we can look out for you.
:rofl:
Blackrose
538
thanks guys. Where can I purchase the movement from. I would most likely get a clone 2836. Is the bay a good place to loo? Thanks again everyone.
@intheshadows I apologize if this is in the wrong sub-thread
